| Support JF - Equipment Drive and Future Downtime |
| Register | FAQ | Mark Forums Read | Search Members |
LinkBack (8) | Thread Tools |
#1 | |||
Registered User Join Date: Apr 2004 Location: San Jose, CA Posts: 1,467 | Harbor Freight vs Costco Portable 12v Air Compressor - In Depth Review w/ Pictures
__________________ 1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! Last edited by RickyN29 : 02-20-2007 at 11:09 PM. | ||
| #2 | |
Registered User Join Date: Apr 2004 Location: San Jose, CA Posts: 1,467 | Some notes: The power cables on the HF unit are substantially beefier. This is important too because as discussed later, these units pull about 30amps under load. Both cables get very warm during operation, I prefer the HF cables. Thicker gauge, and heavier duty clamps: HF: ![]() Costco: ![]() The Costco unit has a handy little feature, the nozzle acts as a tire deflator. Once screwed on to the valve stem, simply turn and it will deflate the tire, handsfree. Very handy and easy to use. The HF unit does not have this feature ![]() Although not important, I do like that the power switch on the Costco unit is weather/dirt proofed. ![]() __________________ 1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
| #3 | |
Registered User Join Date: Apr 2004 Location: San Jose, CA Posts: 1,467 | Here are some comparison pictures between the two units: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
| #4 | |
Registered User Join Date: Apr 2004 Location: San Jose, CA Posts: 1,467 | Noise: Both units are extremely quiet. They both have rubber feet. (HF Unit has rubber feet attached to metal base, Costco just has rubber feet). Decibel wise, both units are almost the same. Costco unit has a higher pitch compared to HF unit. Air intake (filter unit) is easily replaceable on Costco Unit and does a good job of muffling the sound. It is also higher up to avoid sucking in loose dirt/dust from trails. ![]() ![]() Storage: One of the selling points on the Costco unit is it's small footprint and case. The HF unit comes with a very nice hard case, however, as you can see in the photos at the beginning, it takes up substantially more room. The Costco unit comes with a much smaller canvas storage bag which holds all pieces in nice separate compartments. ![]() ![]() WD-40 Can for comparison: ![]() ![]() ![]() ![]() ![]() __________________ 1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! |
| #5 | |
Registered User Join Date: Apr 2004 Location: San Jose, CA Posts: 1,467 | Power Consumption: Both units under full load exhibit and very similar amperage draw (around that rated 30amps: HF Unit (@ full load): ![]() Costco Unit (@ full load): ![]() At no load, both units drew about 18amps: ![]() ---------------------------------------------- Now the most important part! SPEED! The Costco unit is substantially faster. Costco: From 0-40psi on a 31" tire took 3 min 10 seconds HF: From 0-40psi on a 31" tire took 5 min 30 seconds An important note: The HF unit runs EXTREMELY HOT. Touching the head of the unit will result in a severe burn. The Costco unit runs warm, but within an acceptable handling temperature. If you plan to hardwire either of these into your Jeep, make sure to use properly gauged cables as these units draw 30amps continuous. Depending on length of cable, I would recommended 8 gauge +/-. Costco Unit in Action ![]() Begin: ![]() 5 minutes later: ![]() -------------------------------------- Conclusion: In my opinion, the Costco unit is the way to go. It is faster, smaller, runs cooler, and comes with a more flexible storage case. Not to mention it is also cheaper in price! The Costco unit claims on the box to fill up a 33" tire in 4 minutes or less. I find that to be a fair estimate. The HF unit is definitely pretty, but takes up more space, runs too hot, and takes longer. With the excessive heat the HF unit generates, I foresee it wearing out with a lot of use. The case is nice, but too bulky. I would give the HF unit a 7/10 and the Costco unit a 9/10 (for average users). __________________ 1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! Last edited by RickyN29 : 02-20-2007 at 11:14 PM. |
| #6 | |
Registered User Join Date: Apr 2006 Location: Portland, OR Posts: 209 | are they comparable in output? EDIT: i scrolled too far...disregard =-D __________________ [URL="http://www.myspace.com/gatmog"]xj video on my myspace page[/URL] |
| #7 | |
Registered User | If you look in the more recent Quadratec catalogs, you will see that if you take the handle off of the HF pump and paint the filter black....it is identicle to one of the ViAir pumps they sell for like $275.00 I bought the HF pump and am using it for my OBA, mounting it in a "box" where my airbox used to be and having it fill 2 tnaks where the spare used to be inside. __________________ EC4WDA sand/mud racer slant six/NOS/20.5" wide sand paddle tires 2004 KJ...the wife has to drive something 1979 CJ7: 4" springs, 2.5 shackles, 35 procomp M/Ts, 360 auto, quadratrac, rear discs, ramsey winch, lock right, overall good time... |
| #8 | |
Registered User Join Date: May 2006 Location: Staunton, VA Posts: 826 | Did you test more realistic pressures? Like 8psi to 30psi? __________________ 03 Rubicon RE 3.5" and 1.25" JKS BL 285/75/16 Kumho MT's |
| #10 | ||
Registered User Join Date: Apr 2004 Location: San Jose, CA Posts: 1,467 | Quote:
8psi to 32psi took 2.5 min (on the HF unit) Costco unit was not tested for the 8-32 yet. __________________ 1990 XJ Laredo 4x4 Auto *Rusty's ~6" Lift *Dana30/Dana44 3.55's *Pacer Wheels/High-Tec Retreads 31" MT *KargoMaster Safari Rack *CSF Open Cooling System Conversion *Hayden Tranny Cooler *Flowmaster 40 Delta & High-Flo Cat *PORC SYE / FRT DS Combo *The Doors are off again for summer! | |
| #11 | |
Uncle Paul has spoken... ![]() Join Date: Feb 2005 Location: Camarillo, California Posts: 2,610 | First, I have never seen that many pictures of an air compressor. Second, I have the red one. The more realistic air pressures are from 15-30. On my 33 x12.5x15 tires is only takes about 1.5 - 2 minutes to air up. Really fast. Thanks for the writeup. __________________ My Jeep - Video My Jeep in the Snow 92 YJ, 35' MTR Kevlars, TeraLow 4:1, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, Go-Fer-It tie rod flip, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 8000lb MileMarker winch, Winch Saver, in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com), scanner, GPS, CB. |
| #12 | ||
| #13 | ||
Uncle Paul has spoken... ![]() Join Date: Feb 2005 Location: Camarillo, California Posts: 2,610 | Quote:
As for the heat, I found that the red one also gets too hot to touch after airing up all four tires. In fact, the first time I used it I thought something was wrong. __________________ My Jeep - Video My Jeep in the Snow 92 YJ, 35' MTR Kevlars, TeraLow 4:1, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, Go-Fer-It tie rod flip, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 8000lb MileMarker winch, Winch Saver, in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com), scanner, GPS, CB. | |
| #14 | |
Senior Member | This is a good posting! Thanks for trying the water for those of us who are looking for OBA. Great pics too. __________________ Black Jeep Club v1.0 and v2.0 #1776 DR Z MUST BE STOPPED #7 |
| #15 | |
Registered User Join Date: Jul 2003 Location: Salt Lake City Posts: 1,080 | Nice work, Ricky. Bill __________________ 2003 Rubicon auto w/3" TeraFlex System & 33" Goodyear MTR's TJ Ruby Pic 1 TJ Ruby Pic 2 2007 Unlimited X 6sp 4dr w/3" lift and 35" Pro Comp X-AT's JK X Pic 1 JK X Pic 2 2009 Grand Cherokee Laredo 4x4 2009 JK Sahara auto 4dr 4x4 |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Harbor Freight OBA..anyone??? | DeesTJ | General Jeep & Off-Road Equipment | 19 | 01-30-2010 09:22 AM |
| Question About The Harbor Freight Coil Spring Compressor | Nick B | General Jeep & Off-Road Equipment | 22 | 10-11-2009 08:37 PM |
| Harbor freight | frumpy | General Jeep & Off-Road Equipment | 20 | 12-09-2007 09:09 PM |
| Harbor Freight air compressor | HeavyMetal | General Jeep & Off-Road Equipment | 4 | 02-24-2006 06:34 PM |
| PORTABLE 8,000 lb. WINCH Harbor Freight | JEFFP | General Jeep & Off-Road Equipment | 10 | 12-23-2004 03:41 PM |
Previous Thread
Next Thread
