| Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE |
| Best place to buy Rubicon Express! Don't Fear the Jeeper! | Insane Rough Country Deals Call for more Info!!! so insan | Barnes 4WD Universal 4 Link Kit |
| Jeep Registry | Register | Blogs | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Do it right or not at all
![]() Join Date: Jan 2003
Savvy's new prototype aluminum rocker guards, LED tail lights installed
Please be on the lookout for my stolen TJ. See it at http://members.cox.net/jerrypb/ Getting Savvy... Coolest offroad magazine ever! Crawl |
#2 |
JEEP FREAK
![]() Join Date: Apr 2004
Very nice.
98 TJ 02 WJ |
#3 |
how strong are those compared to steel. they look beefy but its still aluminum.
2003 white rubicon on 37s http://farm4.static.flickr.com/3374/3258900652_92376a0a33_o.jpg I need 1 37x12.5x15 tire. any condition near MA |
#4 | |
On top of that, the designer of these skids has been a long-time Johnson Valley wheeler (the hardest of the hard-core rock crawling areas) who has had a T-6 6061 aluminum engine skid under his TJ for many years and while it is well gouged up, it's not been dented. No worries, this is not your grandmother's aluminum. Not to mention that Savvy's warranty is that if you can break them, they'll replace them. ![]()
#5 |
I guess we start critiquing these now.
They are very cool very unique looking and much like the other savvy products I WANT THEM. My problem, i want them in black... and they seem like they need a little grip on top because of the slope. Other then that yet another fantastic savvy product i will be waiting and saving for. |
#6 |
I'm sure strength will not be an issue.
Jerry, do you know if the plans include powder coating or more along the lines of the gas tank skid? A question for Savvy tech support. Do you have a unlimited rubi to use as a beta tester?? I'm guessing your covered but being the team player I am, I'm here for ya...... ![]() |
#7 | |
#8 |
They're so sexy. The part that mounts to the body is aluminum. The actual rocker is steel, bolts on and is replaceable. Amazing craftsmanship and thought put into them.
#9 |
So steal bolt on step... Possibly different options of steps to use. GENIUS
We should all start speculating so when blaine and gerald come in they have pages of lies and false hopes to sort through. |
#10 | |
When we set up the press brake to do that bend on the first few, the brake had a little issue with the hose in the reservoir and would only put out 35 tons of 60 tons of rated pressure. It wouldn't do that bend at 35 tons. ![]() The slider is made from 1/8" 304 S/S. If you look at the tonnage chart on a press brake, when you bend S/S it takes 1.5 times as much tonnage as mild steel. The slider is also reinforced along the bottom edge from the innermost part of the edge out to the start of the radius at the bottom with another piece of 1/8". That gives you 1/4" of Stainless Steel at the flat part and the generous radius of the slider will let it not dig into the rocks. The top of the slider is angled upwards slightly and will act as a brace to the whole lower portion. The angle also stops birds from roosting on them and lets the rain run off plus it sticks out from the body just far enough to protect the door sill in the rocks. All of the hardware is structural. No Allen head fasteners to be found anywhere. Since there are several places where you have to thread into nutserts, you have to achieve the correct clamping force from driving the fastener and you simply can't do that with flat head Allen S/S fasteners. The slider can also be removed without removing the tub backer, flipped around and moved to the other side.
I am Savvy |
#11 |
#12 | |
Gerald is already out shopping for grip tape. ![]()
I am Savvy |
#13 |
#14 | ||
No, strength is not an issue.
I am Savvy |
#15 |
Now back to the black anodizing. The tail light thread got a little technical on me and i may have passed over the info i was looking for. Does that anodizing hold up to sun and fading. Scratching isnt a huge issue as rocks are uncommon here but i like the look of them and the qualities of aluminum.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| aluminum rocker guards | elephantrider | TJ Technical Forum | 5 | 12-06-2009 04:19 PM |
| Aluminum rocker guards? | czjeeper | YJ Technical Forum | 10 | 09-10-2009 11:42 AM |
| Aluminum Rocker Guards | JA66 | TJ Technical Forum | 3 | 10-25-2006 11:15 PM |
| Big Daddy Offroad Aluminum Rocker Guards | DoubleUp686 | TJ Technical Forum | 13 | 09-16-2006 05:48 PM |
| BDO Aluminum rocker guards | baron | TJ Technical Forum | 1 | 05-31-2006 04:15 PM |
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
