I bought my 24 Wrangler Sport S 4X4 in Oct 24. It had 22 miles on it. On the way home from dealer the "Service Transmission" message came up. Took it into service dept, they couldn't find anything' Message was off by then. Said most likely a loose wire, if it happens again bring it back. within the next week it came on again but went off before getting to dealer, this keeps happening randomly. taken it to dealer and each time the message is not on and of course nothing found amiss. now at 10,000 miles just so happened right near the dealer when it came on, took it in they kept it overnight and when I went to pick it up they said in was the way i drive causing clutch to heat up. Drive more carefully to avoid overheating the clutch. I'm not a new manual transmission driver and know how to use a clutch. Had a Toyota 4x4 manual for 4 years never a problem. Even if it were my usage, when do i believe the warning to Service transmission? Has anyone else had issues with manual trans? I know several people with similar year and models but all auto transmissions. My thoughts are there was a problem to start with as driving from dealer when new it came on, not enough "abuse" in 26 miles to cause the issue unless something not right to start with. Any suggestions will be greatly appreciated.
