42RE tranny questions
5.3K views 20 replies 13 participants last post by  jeepyard
EDIT: 95 Grand Cherokee, 4.0, 42re transmision and all time 4x4.
Well hear I am begging for answers. Recently got a 95 ZJ with 180,000 on the OD. The guy I got it from said that he had all the seals and what not gone through in the tranny.
Well after about two weeks of having it the tranny would act as if it were slipping in high gear. When I am on the freeway going between 60 and 70 mph it acts as if it wants to downshift. It is just a quick jerk. Sometimes it will do it a few times and sometimes it will not do it at all. There is no loss of power and the RPM's dont change.
I have changed the filter in the tranny and did not see any metal flakes or anything out of the norm. And the problem still persist.
The other problem is that if I hit the gas real hard from a stand still then it acts as if the tranny is not grabbing a gear and makes a terrible noise. It will also do this sometimes on the freeway when it trys to drop down into the passing gear.
Along with the proposed problems it takes it a second to engage from reverse to Drive but not bad.
I am at a loss with this thing so any advice would be appreciated.
Don't quote me on this, but I think Chrysler called the Aisin-Warner AW4 behind the 4.0 a "42RE." All that means is "4-speed, moderate-duty (2= moderate duty, the higher the number the heavier they duty), and electronic control. The Chrysler built RWD transmissions used behind a V8 from that era were the 44RH, 45RH, 46RH, and 47RH (diesel Ram trucks only).
As for the original poster's problem, the "makes a terrible noise" when you nail it from a stop sounds... well... not good. But it could be the transfer case and not the transmission too.
If not appropriate to chime in on this transmission issue thread I apologize.
I am not sure how to start a new thread and this thread seems related to my issue.
I also have a transmission slipping issue on my 97 Grand Cherokee 4.0 / 2WD which I think has the 42RE transmission. I am at around 124,000 miles on it and have had it since about 65,000 miles.
I have had the trans fluid changed out at 65,000 when I got it and again at about 95,000 having the filter changed and the complete fluid change both times.
Fluid is still pink but probably is due another change. It however looks to be about a quart overfilled.
It was shifting fine until I returned home from a 75 mile trip. Toward the end of the trip the
the overdrive stopped working, then it would only shift to second & a few blocks from home it would not shift
at all. It whines when I put it in reverse and will barely move backward. In 1 or 2 or D it barely inches forward
as I try to accelerate. Any help would be appreciated. Perhaps a sensor or the torque converter?
I have the exact same thing happening to mine, I have a '94 2wd. And my Jeep has been doing basically the same for a few months. I was thinking that it's a sensor but I really have no idea and no money to try and figure it out right now.
#20 ·
I had my transmission built on my 98 4.0 with the 42RE and the guy that built it said to remove the factory check valve in the transmission cooler line. He said he would not warranty the tranny if I did not do this. I pulled it and put it back in myself and this check valve is made as a rubber hose assembley at the front of the engine close to the oil pan. He said if the check valve stick it will starve the transmission of fluid and it will die!! I did have a problem last year with it jumping in and out of overdrive at highway speeds that wound up being a bad TPS (throttle position sensor) that had a glitch in it and was tricking the tranny into thinking it was at WOT instead of just a steady cruising speed. Replaced the TPS and it fixed it and that was back in late 2012. :) Just some suggestions!!
I am not sure what I did incorrectly to elicit the above response but I am new to this forum and am not sure
of all the proper procedures. I did read somewhere about searching first for answers and not starting repetitive
threads. That's the reason I tagged onto this one. If I have used the wrong protocol perhaps someone could send a private message to help me understand the correct procedure to follow to ask a question.
I am sincerely looking for an answer for my 1997 Grand Cherokee 4.0 / 2WD transmission problem.
My Jeep is not driveable as it is.
Thanks for any assistance.
#21 ·
Its bad for me to jump to this conclusion but its sounds like the check valve in the cooler line stuck and starved the tranny of fluid. It will most likely need a rebuild and make sure whoever does it gets rid of that check valve or it will happen again. I have four of these jeep in my family and I have done away with the check valves on all of mine since the guy at the transmission shop told me to get rid of them!!!!
sounds like its time for a rebuild on the trans.. You can however hope that its a sensor problem and check the codes. Use the key trick on/off three times and watch the over drive light.
just my 2 cents...these transmissions are like grenades, you just wait for them to blow up. had mine rebuilt @ 130k and now i religiously change the fluid every 30k. when they start to hiccup its usually a long slippery slope, time to save up for a rebuild.
#17 ·
Which trans fits an AMC 4.0L/4.2L? A500? 42RH? 46RH?
Hi All: I am going crazy with this title's question. I need to find a non electronic 4 spd OD trans which will bolt to my 4.2L 6 cyl AMC engine. The CHRYSLER {not AMC} transmission class of A500/42RH and perhaps the 46RH has different bellhousing {starter is on the wrong side for AMC}, hence I must find one that was used only in Jeep. However, I can't find out which Jeeps used the A500/42RH. I don't want a 42RE. I'm beginning to think that A500/42RH were NOT used in Jeep and only the Aisan AW4 and 42RE were. But I noticed that there was a 46RH was used in some Jeeps. Questions: 1. WAS the A500/42RH ever used in any Jeep? 2. If not, then was the 46RH used in Jeep? 3. If so, is the 46RH similar to the 42RH and I can then manually operate the OD and 4th gear with toggle switches? 4. Would the 46RH fit my AMC 4.2L six? Please help. I got to get this project going and done so I can do the Woodward Dream Cruz this year. THANKS! This stuff takes lots of time {and $$$}.
#18 ·
There was no 42RH, XJ's had either AW4 or 30RH (3-speed). ZJ's used either AW4 or 42RE. 46RH was only used on pre-96 v-8 motors, and it's got a different bellhousing pattern to AMC 4.0
So:
1. No 42RH wasnt used on any jeeps as far as I know; 30RH could be your choce but I'd rather go with AX15 manual.
2. It was used on pre-96 ZJ's with 5.2 v8 engines, different bellhousing bolt pattern
3. Yes it's similar, you just need to control the 4th gear and TCC via 2 solenoids.
4. No unless you can fab an adaptor plate
