UPDATE FOR 9/13: I tried a new coil, no luck. I'm also now seeing no spark in the spark tester. I verified that the coil is getting constant battery voltage on one side of the connector. I hooked my oscilloscope to the other side of the connector. My understanding is this wire-- the ignition coil driver delivered from the PCM-- should be bouncing between battery voltage and 0V, hence why the DMM should read about half of battery voltage.
Well, the results don't look like it. It seems like the PCM is delivering something at the right frequency (suggesting the crank/cam sensors are doing their job), but I don't think it's outputting the right voltage to the coil. It basically just bounces between 1V and 3V. I also did backprobe directly from the PCM connector, and it's outputting this signal between 1V and 3V.
This doesn't look right to me, so I'm thinking it's time to swap the PCM unless anyone has an idea of what could be causing this.
Oscilloscope view of coil driver signal. It's going between 1V and 3V with a lot of noise. I was expecting a much cleaner wave since it's being delivered from the PCM, and I was expecting 0V to battery voltage. My setup is attached to this post as well.
ORIGINAL POST FROM 9/09: I've been fighting a dreaded crank-no-start on my '98 ZJ Laredo 4.0, auto, 2wd. I'm using a spark tester between my spark plug lead and the spark plug. The tester lights up, but I'm not getting spark at the plug. See pic below.
Normally this would be easy: bad plugs or bad coil. However, I've tested plugs and coil and neither tests bad. Are my voltages into the coil correct (listed below)? Could it be bad contact with distributor points, a short somewhere, etc that could cause some voltage between coil and plug but not enough for spark? Other recs for tests?
I've gone thru every weak/no spark thread and have gone thru as much diagnosis as I could find. Some details on my condition:
---ONSET---
Have had intermittent crank no start issues over past few weeks. Drove one day without issue, parked at home, and when I tried to start the next day, it would only crank, no start.
---PARTS---
• Crank Sensor: Mopar, about a year old, signal verified with an oscilloscope
• Distributor+Cam Sensor: auto parts store brand, about 3 yrs old, clean points
• Coil: Spectra, about a year old, verified good primary/secondary resistance, verified voltage to coil is
• Plugs: tested with Champions and known good E4s, neither produces spark
• Plug Wires: Denso, less than a month old (also tested with old plug wires but no change)
---TESTS---
• Coil voltages:
- Battery at 12.3V
-Green and red wire at 10.9V
-Gray and yellow wire at 10.9V
-Green and red wire stay grounded, gray and yellow are grounded sometimes
-Primary/secondary resistance both within spec
• Cleaned all grounds and tested for resistance
• Battery fully charged and tested with another good battery
• Tested with another backup crank sensor, no improvement
• Tested with the original coil (not sure if good or bad), no improvement
• Tested with known good spark plugs, no improvement
• Spark tester between coil and distributor (on either end of plug wires) illuminates the tester
• Spark tester between distributor and spark plug (on either end of plug wires) illuminates the tester
• No CEL, no codes
• No spark under any config on any plug
It's a bit hard to photograph while cranking, but with the spark tester between the spark plug lead and the spark plug, the tester illuminates but no spark at the plug.
---ONSET---
---PARTS---
---TESTS---
• Coil voltages:
- Battery at 12.3V
• No CEL, no codes
