I am replacing the left front brake caliper on my CJ7 and have a question about the copper washers that fit between the banjo bolt, banjo fitting, and caliper. I noticed that the copper washers I have have a flat side and a slightly rounded side. Does it make any difference in how you orient the washer? Should the flat side or the rounded side of the washer go towards the banjo fitting? Or doesn't make a difference how you install the washer?
Thanks
Thanks
