Different sized nuts
963 views 17 replies 13 participants last post by  Reverb
This isn't a medical question I'm afraid.
My lug nuts on the rear wheels are. Different size to the front. Is this normal?
The threads on the lug studs themselves should be 1/2" on a stock axle. Are they stock or aftermarket lug nuts?
Stock lug nuts
The stock ones have an aluminum "cover" that sometimes falls off. The standard socket size is 3/4" (also 19MM) for stock lug nuts. If the cover has fallen off, usually an 18MM socket will work to remove them.
Aftermarket lug nuts
Lug nuts can be purchased that are 1/2" thread, but are available in 3/4" and 13/16" socket sizes. Somebody probably just got the wrong socket sized replacement lug nuts.
If it were me, I would replace them with the 3/4" (19MM) socket size lug nuts.
Max :cheers2:
Which has always reminded me of a medical question I can't get answered: "Is it normal for one testicle to be larger than the other two?"
For lug nuts - anytime I get a vehicle that has those silly stamped covers over the nuts, they get replaced inside of a month. Period. That's just one headache I don't need...
Good lord--you have 3??!! :rofl:
Anytime your at the junkyard & find a vehicle like yours, look on the ground near where the wheels were for lug nuts. Usually wont charge you for them if your getting something else. Then when the covers fall off you just replace them for free.
I had the same problem from the PO mismatching the lug nuts. Ended up going to the local parts store and getting a 1/2 by 20 acorn style lug set to replace them with. The original lug set had the keyed lock nuts that were stripped out and a PITA to get off. If you want the locking lugs its fine, but those funky internal keyed lugs can strip out pretty easy so would go with the external splined ones, just my .02.
Rick
