I blew up my 360 V8 Memorial Weekend coming home from the Rubicon in my 1985 CJ 7. Threw a connecting rod out of the oil pan doing 70mph down I80. So the last two months I was kind of over my jeep and just yanked the engine out and let it sit. Now I have caught the bug again and picked up a 77 Wagoneer that had an AMC 401 V8 in it. The engine is most likely tired and will last as long as the other junker I swapped in. Money is tight and this is pretty much the only route I could afford to get me back on the road. The jeep isnt a daily driver so it should be fine for the time being.
Here is a pic of the damage done to the former 360.
A shot of the donor vehicle. 77 Wagoneer Chief Levi edition. Wish it would of been in good shape, might have kept it as a thrasher.
Engine pics prior to being yanked. Damn engine was disgusting. The engine and drive train had a nice coating of oil, grease and whatever else. Looks like at some point somebody swapped in a 4 barrel manifold and did a piss poor job of sealing it back up.
Pulled her out of the shop to lift the engine out. Sure is nice to have a tractor on hand.
Almost rolled the tractor on its side in the drive way right before this pic due to a low front tire.
Started tearing it down tonight.
Plans are to just clean it up, redo all the gaskets from the valley pan up, swap the 2 barrel manifold and carb from the blown engine along with the dui distributor ,flow cool water pump and the 140 watt alternator. Then I will get her painted up and toss her in for some abuse.
