HEI Install on '84 CJ7
3.4K views 8 replies 5 participants last post by  jeepdaddy2000
Hello All, I posted here a while ago about ignition system problems I was having on my '84 CJ7. Tried most everything I read and still couldn't figure out why my jeep would just shut off randomly like I had turned the key off, so I ended up putting in an HEI distributor. Now I can't get it to fire so I'm wondering if there are any common mistakes that happen when installing HEIs that I may have made. I now have good consistent spark on all cylinders but can't get it to fire, even with starter fluid. Tried advancing and retarding timing by turning the distributer. I took the fuel line off of the carb and it has gas up to it after trying to start it. When I checked the plugs, they look dry though. I would think they would be a little wet immediately after trying to start it for so long. Thinking maybe I'm not getting fuel into the chamber for some reason. When I wired the new distributer in I disconnected the ICM so I'm also wondering if that somehow cut power to the wires going into the carb. To hook up the HEI I just cut the power wire going to the ICM and then connected the hot wire running out of the firewall that used to go to the coil into the new distributer, and spliced in the exciter wire to the alternator. That is the way that I learned by watching a bunch of how to videos on Youtube so I very well may have been steered in the wrong direction but the HEI seems like it should be a fairly simple install. Any guidance is greatly appreciated.
Yep, that's how I've got it hooked up. Still not firing though.
Check your wiring again.
Did you actually use the wire that use to go to the coil or did you use the wire ou cut to the ICM?
You should of used the wire that went to the ICM and cur out the wire that went to the Coil. The wire running to the coil is a resistance wire that will cut the voltage going to the distributor to just barely usable levels.
If you have a volt meter, you can check the voltage going to the distributor BAT+ terminal. It should be 12 volts or more when the key is ON. If it's around 9 volts or less you are using the wrong wire to power the distributor.
Is there no fire to the plugs or is the engine not starting?
You can bypass everything and run a wire straight from the battery to the Bat terminal. Try cranking again and see if you have spark.
Pull all your plugs and inspect them to see if they are wet, If so, clean and dry them and spin the engine to insure there isn't excessive gas in the cylinders.
Bring the engine to TDC. Use a small shaft to feel the top of the piston, rotate the crank back and forth till you feel the piston is at the top. Inspect your timing marks. You should be within a couple degree left or right of 0. If not, you may have a faulty harmonic balancer.
Move the crank to 5 before and check to see if the distributor wheel is aligned with the pickup. If not, then rotate the dist till you get it aligned. That should put you within a couple of degrees of your start timing.
Hook up your timing light and crank the engine. Adjust the timing so it fires at 5 before.
Tighten the dist, reinstall the plugs and wires.
Try starting the engine again.
