Installing new tailgate - CJ7
3 reading
1.8K views 60 replies 11 participants last post by  Mister4x4
My CJ did not come with a tailgate it didn't even have a proper cross sill :)
When me and my dad were building it we made the back one piece.
I am redoing it. Cut off both rear quarter panels and the metal that was in place of the cross sill.
Welded on new panels and a new cross sill.
I'm actually doing a bunch of things to the CJ7 before i hand it off to my son.
One of those things was redoing the back and installing a proper tailgate.
I also am installing a new rear bumper that has a swinging tire carrier. Its the Rugged Ridge XHD set.
For some reason i can't find any tailgate hardware for a swinging tailgate. Just the kinds that drop the tailgate down is what i found.
Can anyone help me with finding the swinging tailgate hardware?
Or do you guys think i should just go with the drop down kind? I do guess the dropdown would be fine. And a lot less work.
CJ's had drop down tailgates, the swinging ones are a YJ tailgate.
Yes its a steel tub but really customized a ton. I am not the 1st owner. The tailgate was missing when purchased.
For example the side panels do not even have a stamped JEEP logo.
I am trying to figure out what i can get to at least get close to a 3D side JEEP logo on both sides.
No way im going to replace the panels only for the stamp.
There were CJ5's made that did not have a tailgate prior to 1979 I believe, The CJ7's all had the drop-down tailgate.
There are aftermarket tubs on which the tailgate opening is an option, mostly the aluminum ones, I think.
owns 1986 JEEP CJ7 Base
Reactions: JoonHoss
I doubt that RR swinging spare tire rack is designed for a CJ, so you should take that into consideration. They may state it will fit a CJ, not sure… just something to look into.
Reactions: JoonHoss
I've seen a few that were automatic.
You unlatch it
and it automatically drops down
into a bench seat.
There are other options where the tire carrier swings off of the "replaced" larger bumper.
I DIYed mine on my CJ-5 so that I could get the spare (torn off the side several times) onto the back
of my Jeep with my other goodies. The square bumper is the air tank for my train horn system, and has a
quick connect for my air hose (tires, air gun). I also have slide in sockets on the front and rear bumpers
for my 2 piece canoe rack to anchor into.
I plan on beefing it up a little more with some angle bracing, it's been like this for 25 years.
It wants to sag about 2 inches when I open it, it is still fully functional.
-----JEEPFELLER
#9 · (Edited)
A swinging tailgate is doable, but you'll need to use YJ hardware, sheet metal, etc. My pal Dave (@Mongo228) had to replace the tailgate on his '80 Laredo, but he really liked his YJ tailgate (from years ago), so we talked and I suggested he swap-in the YJ stuff, since he pretty much had to replace everything anyway. He did, and it all worked out perfectly.
The only downside with yours is that you'll need to replace the CJ corners you just replaced with YJ corners to accommodate the YJ tailgate set-up.
If you're pretty much to this point, all you need to do is get a new CJ tailgate with the latching hardware, straps, seals, and hinges, and you're basically done.
Should look like this once you're done. Don't forget to put the hinges on correctly (the other way is upside down) - they oriented the hinges with the hinge part lower so the tailgate was level with the bed surface when the tailgate's open. Pretty clever! A lot of people put the hinges on with the hinge part right at the split, which works, but defeats the original intent since the tailgate winds up more than an inch about the bed surface.
Get some color-matched spray cans and 2K clear coat from a local automotive paint supplier, and it'll be like it was from the factory once again. (I was building my own tire rack in this pic - the bumper-mount is the way to go - especially with bigger tires).
All done - just gotta hang the tire now. Only thing left is to pop some caps into the factory tire rack locations.
Hope this helps!
Mine is a steel tub. But its a very large custom job.
I am getting it back to sort of factory.
I guess just keeping the tailgate as a drop gate is fine.
Thank you all for you great advice and info!!
EZ for logo
Get the dimensions of somebody else's
Or shade over it with a pencil
Have a graphics place make the letters (and desired color)
Line up the correct dimensions on the Jeep
Normally this is like 2 sheets with the graphic between it.
You tape it in place, peel off the bottom sheet, lower the rest of it down
Rub it from the center outwards to avoid wrinkles. Peel the top sheet off.
Everything should be perfectly spaced
Stick you with a fork---you are done!
The only thing missing is the "raised" metal ---- not too many folks will notice!
The AMC police will not arrest you.
Every bit of insignia on my CJ2A is vinyl graphics - See "OWNS" below
-----JEEPFELLER
#14 · (Edited)
Good luck finding another CJ where I live. :)
They are super rare here
I’m friends with a ton of Jeep owners and go off roading a bunch with them.
Great people!!
I have yet to see anyone else with a CJ
Found this on Ebay as NOS
Those things you show are thick and stick on, the adhesive sometimes won't hold up and they fall off,
Or you dumb buddy yanks and snatches on them!
You used to be able to find the exact "stickers" to go over the raised letters in every Jeep magazine.
I did a quick look at quadratec----like $60 for the wrangler one I saw, NOT ME!
I sorta sponged the black on mine a little at a time with like a larger makeup sponge.
This kept me from painting the "Rise" and keeping the letters looking right.
I also Renegaded Mr. JEEP, some fellers think that's evil if it did not leave the factory with that package.
I think the Renegade Decal pretty much screamed "Jeep" back in the '70s and '80s more so then one
with a plain hood. Besides, I like it, it's my Jeep, if you can whack the fenders off of yours---I can play
sticker on mine!
When you get closer to decals, let me know, I'll take closer up pics, lay out the dimensions of the word,
Layout the position on the tub.
The graphics place can work it all out, Get the Jeep clean, they might even install them for you (a less than 10 minute job)
-----JEEPFELLER
#21 ·
I have another dumb question.
I was looking online for the stock windshield nozzle for the CJ. And this came up.
It makes no sense to me. Looks like it just shoots the washer fluid to the sides...
Am i missing something here?
#23 ·
The water fills the nozzles on either side, but the nozzles rotate up and down to aim at the windshield. This is correct.
#22 ·
UN Fing real..
So i finally got to installing the new fender flares i got.
Opened the box and there are 3 rear and one front!!
Ordered through Amazon back in March. So return is not an option. Tried contacting the seller but wont hold my breath...
This is so screwed up. How do they ship 3 rears and one front?? And these things are not cheap...
#27 ·
UN Fing real..
Called Amazon. Contacted the seller.
Will see what happens.
This got me pissed.
#25 ·
No, they rotate only so you can aim them. You center that main body so the nozzles are on either side, parallel with the windshield frame, then rotate the nozzles to direct the stream at the windshield. You can only adjust them up or down once the nozzle is pointing at the windshield (the openings are mostly sideways, not out the ends).
Here's the other side your pic isn't showing:
#26 ·
Thanks i think i understand now. Its because of the slope on the hood. And these have a wide spray pattern.
I'll try them out rather then the aftermarket type.
#28 ·
The seller messaged me back saying they would ship out a replacement fender flare kit the same day. This was on Monday.
Since then haven't gotten anything yet, and keep asking for a tracking number with no response....
I need to learn to open and check things when they arrive :(
#31 ·
Oh wow. You went with the cut-out/pocket-style flares? I originally ordered a set of Bushwacker cut-out's because I needed just a little bit more tire clearances (I upsized to 35" SSRs without going any higher than my 4" Pro-Comp lift, and the front tires buzzed a little on the trailing edge of the front flares). I didn't really shop around as much as I should've, but instead ordered the Bushwackers from QTec. When they showed up, I installed them and instantly hated them because they were just TOO wide for my liking. I later ordered a set of Rugged Ridge 4.5" flares, which aren't quite as annoying to me as the 7" Bushwackers. Interestingly enough, the RR's fit the same holes as the 'Wackers, but actually seemed to fit the Jeep better (you can see the subtle difference in length between the 2 sets).
You don't actually have to cut your fenders to install them... but you do need to drill holes for the mounting hardware. Here's another forum member's Jeep with the 'Wackers, but he didn't cut his fenders (you can still see them poking out from behind the flares):
I only had to trim a little bit to get the clearance I needed:
Here's the difference between 33x15.50 TSXs and 35x12.50 SSRs:
Here we are with the 33S still mounted up (and my old CJ top and early-style doors before the 304 swap - I'm still finishing things up from a huge "swing for the fence" round of upgrades, including the YJ top for bigger glass, and the late-model 'paddle handle' doors - but this is the overall desired look... just gotta get back there now):
I figure things would be OK, but obviously things settled a bit on the first run:
During the first run with the new wheels and after getting the 304 running, and I learned the flares are just a little too close to keep off the tires over hard street bumps. I don't want to go any higher because I can just slide my butt right onto the seat as it sits right now.
Here are the Bushwacker 7" flares - I was surprised they didn't want to go back any further on the front wheel opening.
They also came up short on the trailing edges and hung down a little, kinda like built-in mud flaps.
And they were just too wide for my liking:
They Rugged Ridge flares showed up and I swapped the Passenger front first - which I had to drill a few more holes, since they're shaped a little different (more like I was expecting - the rear is the 'Wacker as still too wide):
The RR's seems to fill out a bit better on the fender than the 'Wackers - no 'leftovers' hanging down at the back:
Another close-up of the Driver front 'Wacker)
Passenger side RR - goes to the edge of the front fender with no hangie-down bits:
I used the same holes and mounting hardware since they lined up (except for 3 new ones on the trailing edge of the front flares on each side), and RR forgot to send the screws:
Much better, width-wise - I like my tires to stick out just a bit.
Sorry if it jumped around a bit. But when I went to the link you provided, and saw "don't want to cut my fenders," I figured I'd share my experience with both the Bushwackers and the Rugged Ridge flares.
Hope that helps!
#35 ·
Nope. As a matter of fact, all three sets are probably made by Bushwacker... or at least they were designed by BW and the others are just offering them for less cost. Beats me. I can honestly say that quality-wise, the RR's are on-par with the 'Wackers, and actually fit a bit better (IMHO). I can't speak to the QTec flares, but I'd wager they probably have a deal with Rugged Ridge to resell them under QTec moniker, and QTec is probably selling more as a result of a lower price tag.
Who knows. Hopefully, they'll make it right.
