I have a 1997 jeep wrangler with the 4.0L, dana 30 / 35
I got a full rear axle (stock 4.11) and his front ring and pinion (4.11) that he pulled out of his 1997 wrangler with the 2.5l motor. My problem is i went to install the front ring and pinion that i bought from him in my front dana 30 (old gear ratio was 3.73) and i couldn't get my crush sleeve to crush! I used air and still couldn't get it to crush. It almost looks like my yoke will not slide far enough into my pinion gear. So do i need a bigger extention bar on my wratchet Or did they use a different yoke on the 2.5L motor with the 4.11 gears? Is there another spacer im not using besides the shim that goes in between the bearing and the teath? What am i doing wrong???
Are there any Jeepers out there that can help me out? Or any teck's that know my problem?
You can call me at 503-314-9747 or email me at brbarnes54@aol.com
P.S.
i have a dana 35 out of a 1996 and older cherokee or wrangler that i am willing to trade for a dana 30 front axle with 4.11 gears that's set up for coil suspention.
Thanks
P.S.
Thanks
