I am wondering if anyone out there has some information on clearing codes for a 1997 sport. I have read that on the YJs it is ok to clear the code by disconnecting the batter for a few seconds. Does this work on 1997s as well?
I ask this because you can also get the codes from a 1997 through the check engine light and odometer using the ignition on and off method, and you (as far as i know from what i've read) can't do this on 1998 and later models.
So can you clear the codes by dissconnecting the battery? or is it recommended not to do this? any ideas?
