What yoke puller do you use to remove from D300?
112 views 3 replies 4 participants last post by  Goodoldjeep
Good day! Welcome any thoughts one what joke pulller you use or different techniques to remove the front driveshaft yoke from D300 transfer case.
This is a ‘83 CJ-7, so I have the straps on thr yolk holding the joint. I have the 1/4 inch 12 spline torx socket, but no yoke puller to remove the 1 1/8 nut and yoke.
I've not pulled the front yoke off, but I did swap the rear yoke on my D300...I needed to add a double cardan driveshaft.
My rear yoke came off very easily after loosening and removing the yoke nut. Just a common two jaw puller and hardly any force, IIRC.
BTW, that original yoke, and the entire D300 sat outside for over 13 years...yours looks waaaay cleaned than mine did.
