Friend of mine had what we believe was a failed coolant temperature sensor that led to a catastrophic situation. Coolant was shooting out of the overflow in the surge tank, as well as both sides of the radiator. From my understanding, one side of the radiator has an emergency blowoff valve to prevent the system from detonating. Well… that didn’t stop the other side from failing under the pressure.
Before I get to my main question, I have a side question. Do you guys think that temp sensor was bad and therefor didn’t tell the fans to kick on, thus leading to the system overheating?
Ok, now to the main event. They want to order a new radiator from RockAuto, but I said let me check my radiator first to make sure it looks the same. Turns out it DOESN’T!
Here is a part of my radiator which I think shows a coolant line. Mine is a 2003 Laredo, nothing special
Now, here is there’s. Nothing is there, just a rubber plug. They have a 2004 Laredo with the Trail Rated package.
Why would the radiators be different from 2003 to 2004?? They’re basically afraid to make the order right now and risking getting the wrong one. Any help would be appreciated!
